Hi
I'm fed up getting so much conflicting information on toe in/out in particular I thought I would come here. I'm doing a wee FF track car (Honda Integra Type R DC2)
The front track is 1480mm, and the rear track is 1475mm. I am using the string method with vernier caliper to measure.
I set the string 50mm from front wheel centre cap, and set the string 52.5mm from rear centre cap to allow for rear track being 5mm less overall. So now the string should be perfectly parallel with the body of the car.
Next I am measuring (on the front right wheel 1st) the difference between the front and back of the rim to the string. I am getting a result of 2mm and the wheel is toed out. So is this wheel 2mm toed out, or 1mm toed out?
Ie if the desired total toe is say 4mm thats 2mm per wheel. Is the definition of toe expressed in mm, the distance between the front and back of rim measured to the string, or is it the difference between the front the rim, and centre of wheel to the string. Ie half the front to rear measurement.
That's all I need to know but everywhere I read I get a different result. Check out my crude diagram.
Is that distance A the toe for that wheel or is it half of that in a nutshell?
