I don't know to much about distributers....I'm more into aerodynamics, suspensions and a little bit about engines and gearboxes!
But it seems to me that they have 2 distributers.....correct me if I'm wrong....but it looks to me that they are using a 4 cylinder engine.....and they are using a distributer for each 2 cylinders....probably a distributer for each oposite cylinders....cause if one of the distributers malfunctions it isn't to good to keep the engine running with only one bank working!
About your first post about the car....in spite the fact that you don't see the torsion bar....it might have one....in some cases the torsion bar is conected to the chassis....what I mean is that in some cases the torsion bar is the area were the rocker is connected to the chassis....is this case in the area of the biggest bolt/nut on the rockers.....but unless we take a look at the car without the rocker it's impossible to know.
About the suspension geometry, I also think it was poorly thought....
Even though it's seems to be a very simple car...with not too many briliant minds behind it!!!!
Notice the upwrights....it seems to me that they're made from aluminum!.....and notice that they're also very simple.....I believe this car might win the simplicity award!!! hahaha
