or this
which is better?
rounded or triangle?
The intake on the top appears to be larger in size than the bottom. If that is the case, how would you consider that the top one will starve the motor more than the triagular inlet???Scuderia_Russ wrote:The top pic is supposed to give better flow to the leading edge of the rear wing but I suspect it also starves some cylinders of their full air intake potential otherwise everyone would still use it. Don't IRL cars run with this airbox configuration?
I said I suspect it would starve some cylinders (probably not majorly, just compared to the other design) and I'm making an educated guess in that respect. That part of my original answer I am not 100% on but I do know that this particular shape was used to aid airflow to the rear wing. I didn't make a refernce to the size of the intake in any way just its shape. What we can't seee from these pics isthe shape of the air intake leading to the air filter.Sodder wrote:The intake on the top appears to be larger in size than the bottom. If that is the case, how would you consider that the top one will starve the motor more than the triagular inlet???Scuderia_Russ wrote:The top pic is supposed to give better flow to the leading edge of the rear wing but I suspect it also starves some cylinders of their full air intake potential otherwise everyone would still use it. Don't IRL cars run with this airbox configuration?
I think that you may have mistaken my post as a criticism, or a sarcastic remark. That was not my intent. I'm sorry...Scuderia_Russ wrote: I said I suspect it would starve some cylinders (probably not majorly, just compared to the other design) and I'm making an educated guess in that respect. That part of my original answer I am not 100% on but I do know that this particular shape was used to aid airflow to the rear wing. I didn't make a refernce to the size of the intake in any way just its shape. What we can't seee from these pics isthe shape of the air intake leading to the air filter.
No, not at all mate. I'm no aero expert (!) and I just wanted to make clear that anything I said was an educated guess based on bits of information I've either read about or cobbled together from here because I wouldn't want anyone taking what I've said as gospel when it was basically only a best guess if you see what I mean.Sodder wrote: I think that you may have mistaken my post as a criticism, or a sarcastic remark. That was not my intent. I'm sorry...
When I took fluid dynamics, I found it to be one of the easiest classes I've ever taken (relatively speaking). I'm proud to say that I was able to hold my own in that class. To this day, I still have nightmares about staying up until 4AM on Wednesday nights (make that Thursday mornings) writing up my 30+ page reports (btw, I'm not kidding about the number) on the lab I did about, say, a flow throgh a venturi meter...Sodder wrote:Yeah that much I can follow. I have not completed my "fluids" classes yet and thats where our aero sections are. Hopefully when the time comes I'll be able to contribute to this section of the board more intelligently. Instead of just rambling on like a bafoon....
And of course, that is weight from the highest point on the car...........scarbs wrote:The change in airbox shape was not an aero thing, but a Honda lead development to make the monocoque lighter, they developed a new shape and lay up for the roll structure. (no arguing Geoff Willis told me)
Having seen CFD demos of F1 airbox design, its clear the aerodynamic mechanisms in use are far form intuitive. I doubt you could predict which inlet would be better for the engine.
Scarbs
