Are there some softwares or a method to find the exact surface which helps give an optimal performance?
I have defined a line and the cross section from which the nose needs to be lofted in my CAD between which I need to form a surface (say upper surface of the nosecone). How can I get a best possible surface? Do I need to create many and simulate them all or is there a shorter method?
Say in mercedes's rear wing, how can I define the middle curve part?
