Hi All,
I have been heavily researching ground effects, I am in no way an expert unlike many on this forum, and I have come up with a conundrum. I see what Chaparral originally did with his front skirt of the 2J:
Notice the double skirt goes from left to right behind the front wheel (like a air/mud flap), then the main skirt behind that actually attempts to seal the underbody gap to the road.. This skirt sees the full frontal windage and, move up and down with the road surface.
What I am hoping is that I can make the front skirt more efficient by doing a 'V' shape instead of a straight skirt from left to right, but what I cant get past is how to effectively design a V without having a mass air gap where the two points meet. OR if some one else has a brilliant design so that the front wing removes the air from the skirt sufficiently so as not effect the skirt then that would be awesome also!
Perhaps the exhaust air from the twin downforce fans could blow forwards into the middle area, where the skirts meet? I'm not sure on the resistance calculations would be to cover the area (probably an area of roughly 100mm).
