The lift theory (for aircrafts) we all learn in school goes:
The air moves faster over the top of the wing and therefor the pressure on top of the wing is lower than the pressure beneath it.
This explanation is based on the believe that the air above and below the wing will meet at the trailing edge at the same time. It is called the equal transit theory.
Yet- this is wrong. You can't simply assume that the air molecules have to meet again at the same time. And they don't(0:45) :
This is why NASA says that this is the incorrect lift theory: https://www.grc.nasa.gov/www/k-12/airplane/wrong1.html
I, for my part, believe that NASA is a credible source.
Other websites say that this theory is flawed too: http://www.allstar.fiu.edu/aero/airflylvl3.htm
please have a look on the airfoil in the link. It is obvious that no aircraft has an airfoil like this.The usual claim is that when the air separates at the leading edge, the part that goes over the top must converge at the trailing edge with the part that goes under the bottom. This is the so-called "principle of equal transit times".
As discussed by Gale Craig (Stop Abusing Bernoulli! How Airplanes Really Fly., Regenerative Press, Anderson, Indiana, 1997), let us assume that this argument were true. The average speeds of the air over and under the wing are easily determined because we can measure the distances and thus the speeds can be calculated. From Bernoulli’s principle, we can then determine the pressure forces and thus lift. If we do a simple calculation we would find that in order to generate the required lift for a typical small airplane, the distance over the top of the wing must be about 50% longer than under the bottom. Figure 1 shows what such an airfoil would look like. Now, imagine what a Boeing 747 wing would have to look like!
Also:
Not good.If we look at the wing of a typical small plane, which has a top surface that is 1.5 - 2.5% longer than the bottom, we discover that a Cessna 172 would have to fly at over 400 mph to generate enough lift. Clearly, something in this description of lift is flawed.
However after this theory is deemed wrong the link has another explanation for lift:
The source once more: http://www.allstar.fiu.edu/aero/airflylvl3.htmThe lift of a wing is equal to the rate of change in momentum of the air it is diverting down. Momentum is the product of mass and velocity. The lift of a wing is proportional to the amount of air diverted down per second times the downward velocity of that air. Its that simple. (Here we have used an alternate form of Newton’s second law that relates the acceleration of an object to its mass and to the force on it; F=ma) For more lift the wing can either divert more air (mass) or increase its downward velocity. This downward velocity behind the wing is called "downwash". Figure 5 shows how the downwash appears to the pilot (or in a wind tunnel). The figure also shows how the downwash appears to an observer on the ground watching the wing go by. To the pilot the air is coming off the wing at roughly the angle of attack. To the observer on the ground, if he or she could see the air, it would be coming off the wing almost vertically. The greater the angle of attack, the greater the vertical velocity. Likewise, for the same angle of attack, the greater the speed of the wing the greater the vertical velocity. Both the increase in the speed and the increase of the angle of attack increase the length of the vertical arrow. It is this vertical velocity that gives the wing lift.
Saying that it is the downwash that generates lift.
And Peter Prodromou agrees. At 1:25 "...the wings purpose is to divert the flow down."
BUT
It all goes wrong when it comes to ground effect. The link above says in the last paragraph (really worth a read on a test day) that ground effect exist because the ground minimises the upwashed air ahead of a wing which causes negative lift (downforce) on airplanes. The link also says that the upper surface is much more important for lift because the coanda effect is very powerful and allows to divert a lot of air above the wing down.
And now we have a look on F1 cars where everything is upside down.
First of all the diffuser: If we want to create as much upwash as possible it makes less sense to drive as low as possible to the ground. The incorrect lift theory makes much more sense on this. It makes sense that the low pressure beneath the floor and the high pressure above it creates downforce and not the upwash behind the floor.
Also the front wing:
why would you run it so close to the ground? It diminishs the amount of air than can be diverted upwards. And as we know it is the outside surface that is important for the upwash.
The questions are: Is the explanation of lift based on upwash and downwash just as flawed as the explanation of lift with the equal transit theory? Is downforce on F1 cars not rather the product of different pressures above and below the wing?
And last but not least: What is the correct lift theory in your opinion?
Have a nice (testing) day and enjoy reading the links above. It is worth it
