I am a big fan of rwd, I grew up around them, but recently I been taking a liking to fwd cars, they give you a new feel and my new daily driver is fwd. But back to the mini, I am trying decide on which drive sytem to go with, the main thing I want is great handling that's my main concern everything else is second, I would like to keep it fwd since it's a very simple setup and very compact since everything is upfront, but if I am at a great disadvantages when racing against rwd car, then going the rwd route would be the better option. So I ask the question to see if any one had any suggestions to help tackle the disadvantage that comes with running forward wheel drivestrad wrote:I would not suggest converting a Mini to rear wheel drive but in general I despise FWD. Giant farce perpetrated on the public to make it cheaper and easier for the manufacturers.
Well then you do not want FWD with it's inherent understeer.. not to mention it's short wheelbase .. ever seen footage of Mini rollovers? Or any short wheelbase front wheel drive car?the main thing I want is great handling that's my main concern
pros and cons:Speed898 wrote:Yea rollover iso taken into consideration. I plan on lowering the car, upgrading the suspension and adding aero parts to it.
I want to do something similar to this
http://jalopnik.com/5397825/huge-front- ... n-tcs-fwd/ with the mini, since I seen this car run before and it amazing that its a fwd car. But if you guys are recommending for me to go with rear wheel drive instead I will look more into it, I just want to see if I could still work with the fwd design of the mini without having to chop up the chassis.
The rwd kit basically looks like this http://www.minimania.com/COMING_SOON__V ... heel_Drive_Tim.Wright wrote:How does the RWD solution work? Is the engine also mid/rear mounted? I assume the the suspension would have to be completely new too sin the stock spindles wouldn't have the necessary interface for a CV joint.
This is the important stuff to know as I can't imagine anything worse handling than a RWD drivetrain in a front weight biased vehicle designed for FWD.
Actually quantitatively calculating the advantage is tricky due to there being so many factors that make up basis for how a vehicle handles. The major reason that RWD is superior to FWD (oversimplified), is the transfer of effective sprung weight of the vehicle (as people here have mentioned). Basically, as a car accelerates, the centre of mass is shifted backwards which means that there is more weight over the rear wheels; This serves to increase the normal force between the rear tires and road surface. As frictional force is directly proportional to this (normal) force, the rear tires have increased grip under acceleration. The same principles apply with deceleration (braking) which is why our main braking system (brake pedal as opposed to handbrake) is on the front wheels. In vehicle dynamics terms, the transfer of effective mass is explained by Einstein's theory of equivalence, that the effects of gravity and acceleration are equable. This means that as you accelerate, it's as if gravity is acting on the rear of the car more than the front.Speed898 wrote:... just how much of an advantage does rwd have over fwd?
Vyssion wrote:Essentially, the generation of downforce is the way that allows for the car to (in lamans terms) "be heavier than it actually is, without the bad stuff that comes with an increased weight".
The downforce and the normal (weight) force of the vehicle is the simplified mechanism by which the tyres gain their grip. And again, over-simplifying things for a purely aero discussion, the more grip you have, the faster you can theoretically corner at.
(Can't display an actual 'mu' symbol so will refer to it as C_f from here)
The "N" denotes normal force which is made up of the vehicles weight force and any downforce currently being produced.
If you combine this equation with the formula for centripetal acceleration (which could be adapted to fit a corner if a constant radius)
and rearranged to give:
Then you get the following formula:
This then shows that for a constant coefficient of friction, that velocity is proportional to(meaning that an increase in the right hand side of the equation will increase the left hand side). If this is differentiated to get this in terms of time, it shows that time is proportional to
(or simply that it is inversly proportional).
The important term here is thiswhich is often referred to as the "specific downforce" of the vehicle. So if we are to increase this term, by means of increasing downforce or reducing the cars mass, the theoretical maximum velocity we can corner at will increase and hence the time taken to travel the corner will decrease. Add in that since you can carry more speed through the corner, braking time is reduced in the lead up to it and the acceleration beyond it begins from a higher speed, and you can begin to see the benefits.
By increasing mass initially, this would have the effect of decreasing this term, which would be counter productive.
This argument here is purely from an aerodynamic standpoint (and extremely simplified!!!) though and doesn't even mention things like the weight transfer or suspension changes and other vehicle dynamic effects that would be required to handle the higher initial weight during a race. But hopefully it helps explain why it is the way it is!!
I am not looking specifically for a rwd car, I just want a track day car, something I can take on the weekend to the track, I already have the mini and it just sitting in my garage, since I bought a new daily driver. The conversion for turning it rwd is not as uncommon as you may think. Most kit are pretty good and it just a matter of cutting the chassis a bit to get everything to fit and welding/ bolting it in place. Apart from having the mini already, I also have a savage hayabusa engine that I bought at a junkyard not so long ago for a really, really good price and that will be it's new engine for it. Again I would like to keep it fwd but from what everyone is saying it looks like rwd would be my best option, apart from going with electronic aids which I am pretty sure I can't afford it and I never seen any for sale to the general car market.strad wrote:Whoa ,Whoa, Whoa
IF you want a RWD car..Buy one..I can not see chopping up a Mini to turn it into a RWD car with no doubt many problems to be sorted....go the easy way and get something you like that's rear wheel drive to begin with.
