The only real difference is that the braking torque has to go through the half shafts. So you design the brake with basically the same parameters and beef up everything between the brakes and the rim to accomodate the additional brake torque.teammaverick wrote:in case of outboard braking we took torque at wheels to calculate braking torque but in case of inboard braking we apply brake at differential...so wht torque should be consider?and is there any factor needs to be consider for half shafts while designing?
teammaverick wrote:I have limited slip differential in my car.So where should i place brake disc on it?
The torques will be almost the same. The only thing that changes is the slight axis changes of the CV joints and the torsional rigidity of the shaft. So not much more additional braking torque is needed.teammaverick wrote:in case of outboard braking we took torque at wheels to calculate braking torque but in case of inboard braking we apply brake at differential...so wht torque should be consider?and is there any factor needs to be consider for half shafts while designing?
