The flipups on the sidepods in that picture have become two element wings. On the McLaren, the front wings are three elements, and the rear wings two elements. Each element interacts with the other, and they contribute more downforce. In this case, two is better than one, and sometimes three better than two. As a side note, three element rear wings are not allowed by the rules, or we would probably see them there too.
For the speeds and lift versus drag desired, this system works best right now. You can see something very similar in an aircraft flap system, which is designed for lots of lift at lower speeds.
The wing device on the engine cover does not directly generate lift in itself, but it smooths and redirects the airflow in that area. That airflow later impacts on the rear wing, and it is more efficient than of the air was not conditioned by that airbox element.
