Thanks. I named the files incorrectly. Will check more carefully next time.AnthonyG wrote:I think you confused qualy results with race results and vice versa.
It happens. I'm glad you put in the effort to make an elaborate opening post!ChrisDanger wrote:Thanks. I named the files incorrectly. Will check more carefully next time.AnthonyG wrote:I think you confused qualy results with race results and vice versa.
Thanks. I enjoy putting them together, and making some small contribution to the site. I sometimes work on them when I'm a bit tired though, hence mistakes get made. I appreciate the gratitude though.AnthonyG wrote:It happens. I'm glad you put in the effort to make an elaborate opening post!ChrisDanger wrote:Thanks. I named the files incorrectly. Will check more carefully next time.AnthonyG wrote:I think you confused qualy results with race results and vice versa.
In the video pointed out by thumbs up (apparently originally from you) it says inside aka apex is raised 1m and that it is now off camber.godlameroso wrote:Have you seen the new version @ racedepartment? I don't know how accurate it is(the final turn is cambered in not off camber) but the fact that you can be aggressive with the inside curbs makes a huge difference.
I wouldnt say that he has been clearly better. I would say that being in front of Nico he has been able to manage well the tyres, much better than he used to do in the past.PhillipM wrote:That's a bit of strange reasoning you have there when Lewis has been better on the tyres for about 2 years
