JCB Streamliner
flynfrog
JCB Streamliner
You may have noticed the JCB logo on the back of the Williams this year.
http://www.williamsf1.com/racing/news/w ... artnership
Did you know they ran over 350 MPH on the salt at Bonneville .
The story is pretty interesting. The used modified engines from the back of their loaders. On the salt there is very little traction and the stream liners are very slippery. With the two engine configuration they would get enough load into the front engine to have it come up on boost while the rear engine would not build boost and go along for the ride. The driver Andy Green would try dragging the brakes to put more load into the engines. They eventually ran a pipe connection both plenums so that both engines would see the same boost helping them both come up to power. Then they found a software problem where the engine would think it was in neutral can cut fueling.
The story is a lot more complex that this and if you are interested I suggest reading this.
http://www.ingenia.org.uk/Ingenia/Articles/428
Facts Only
Facts Only
188
Re: JCB Streamliner
Apparently it never actually made it into top gear which would have seen over 400mph but because they already had the record there was no point pushing further. Also the compression was lowered so much to run the massive boost that the engine could barely run at idle.
I believe the car now resides in the JCB museum in the uttoxeter world HQ
bdr529
59
Re: JCB Streamliner
You may also notice a young lady in the film, Teena Gade she's the sister of Audi's former race engineer Leena Gade
flynfrog
Re: JCB Streamliner
Facts Only wrote:Apparently it never actually made it into top gear which would have seen over 400mph but because they already had the record there was no point pushing further. Also the compression was lowered so much to run the massive boost that the engine could barely run at idle.
I think they were still have engine troubles when they set the 350MPH record running 365 the first leg then a much slower return leg.
J.A.W.
J.A.W.
109
Re: JCB Streamliner
For comparison, this big ol' truck, 'Phoenix' - using modified 1940's tech got a record of 272 mph..
https://www.youtube.com/watch?v=57i8OU1m4rk
flynfrog
Re: JCB Streamliner
J.A.W. wrote:For comparison, this big ol' truck, 'Phoenix' - using modified 1940's tech got a record of 272 mph..
I missed out on the Diecast of that truck.
http://www.ugofadini.com/phoenixmodel.html
