This thread is to investigate the technical legality of the hole in the nose of the RB13 car. I notice the tech writers have avoided an explanation as to how it works.
That leaves f1tech again to lead the way.
Anyone care to begin?
Yep. I saw that video. Scarbs doesn't explain anything there. He gingerly skips over any technical explanation.JonoNic wrote:https://www.youtube.com/watch?v=KIBUCV_4sio Scarbs POV
It does, As ted shows in the above video it uses the same regulatory trick that Lotus used for the ugly tusk nose a couple of years back.Just_a_fan wrote:There was some suggestion that the inlet contains a series of fins that maintain the legality of the device. Much the same as the FI clever geometry to ensure the device, when viewed as a section will always be a not-hole.
Like he does more often than not?PlatinumZealot wrote:Yep. I saw that video. Scarbs doesn't explain anything there. He gingerly skips over any technical explanation.JonoNic wrote:https://www.youtube.com/watch?v=KIBUCV_4sio Scarbs POV
Ok. I have a hint from a RedBull employer. The nose is legal using the same principle of the Force India nostrils.
It's the internal vane structure that allows both to be legal from a cross section point of view, lotus used these too.PlatinumZealot wrote:When Ted said it uses the Lotus trick he made a mistake. It cannot be related to the loust trick.
The lotus trick was to have a crash structure on one side of the nose, with a vanity structure on the other side of the nose. The tip of the vanity structure was 50mm shorter than the tip of real nose cone. In doing that, Lotus met the cross sectional area requirement at the given plane while at the same time having second structure to make a tunnel for aero reasons.
I can say with full confidence that the Lotus twin tusk has nothing in common with the red bull nose.
Explained in that video, on the drivetribe link below and on twitter, all at the timePlatinumZealot wrote:Yep. I saw that video. Scarbs doesn't explain anything there. He gingerly skips over any technical explanation.JonoNic wrote:https://www.youtube.com/watch?v=KIBUCV_4sio Scarbs POV
15.4 was modified that the crash structure has to be symmetrical. This killed the Lotus walrus nose. Which has nothing to do with the Loutus turning vanes under the front fuselage.Furthermore, all lines drawn normally and externally to a vertical cross-section taken 150mm
ahead of the front wheel centre line and perpendicular to the car centre line, must not cross a
vertical longitudinal plane lying on the car centre line.
@ your first image. The top and bottom segements are allowed to be disconnected to allow for driver cooling hole.Powy wrote:I've read Scarbs's article, and this is my take on it:
Connection between top and bottom
Vertical vanes in a V-shape
