Thanks, all. Greg, hollus, good posts. bhall, maybe the teams keep track of such weather conditions in the interest of how they will affect airflow & drag.
My assumption was that downforce would slightly increase, due to the weight of the rain drops increasing the mass of the air. Keep in mind that raindrops are also in free-fall, so it is not only that we should factor in their weight at 1g, but also their velocity. Thus you might say this slightly heavier air will be slightly heavier again. But the slightness of the slightly is probably very slight indeed.
There are other factors to consider, such as: does rain help or hinder flow attachment? Does rain influence vortex formation?
I wonder if teams have ever developed rain wings for rainy races. I assume suspension set up and wing angles at least get adjusted if rain is forecast.
Now, how about engine performance? I assume that, after the air filter, the rain is converted to mist or vapor. Unless the filter gets really soaked. Will more humid air help or hinder combustion, compressor and/or turbine efficiency?
Also, all the cars should be disqualified during rain races. Using phase change cooling media to aid radiator function is explicitly prohibited by the rules, yet each team does exactly this when drive their cars through the rain, and the rain hits the radiators. Kudos to the first team that takes advantage of this by seeing rain on the horizon, and deciding to pit the car before it gets wet. They would win that race on a technicality.
