Do you still think the added surface of the shark fin doesn't make them more sensitive to crosswinds?
I think Barcelona has proved my point. It only makes sense.
They most likely do. However, having a negative effect in crosswinds does not defeat it's original purpose
Thank you! That was my point way back.They most likely do. However, having a negative effect in crosswinds does not defeat it's original purpose
