Came across a AMuS article today that i think warrants its own topic. If not, mods, feel free to move things around.
Typing this from mobile at the airport, hope there arent too many errors/typos.
Link: http://www.auto-motor-und-sport.de/form ... 22370.html
Translated points:
- 5 teams are using hydraulic suspension systems at the rear
- these are Mercedes, FI, RB, TR, McLaren
- the hydraulic components control the ride height and spring rate and roll
- most systems are hidden in the gearbox structure and invisible to the outside
- indications are that teams are and can manipulate the systems with the temperature of the oil of the hydraulic system
- more heat, higher, cold lower ride height
- Oil is pre heated before QF and Race. Therefore, the characteristics are changed during park ferme
- FIA is clamping down on this since Baku, saying that pre heating is not allowed
- This means drivers have to drive more aggressively when going to the grid to get heat into the oil
- Mercedes is rumored to be using a more sophisticated system as the oil lines go through where the oil of the gearbox and thus can heat it this way
- its impossible to the regulate for now because its completely internal and its a grey zone area
- for 2018 they can only ban hydraulic systems if all vote for it, 2019 this may be disallowed
- rumour has it that Mercedes is using this system to better control their efficiency with the tires and keeping heat in them
I am on the plane now, hope i got most of it and its all accurate. Link above for those that speak and understand German.
