Chene_Mostert wrote: ↑16 Sep 2017, 17:46
This whole wet / dry, quali / race, setup differences is a total myth. Teams bring the optimal DF / mechanical setup to the race based on their simulations and the just tweak the balance to driver pref / track variation.
your statement is contradictory in itself
wet times are 10% or more slower than dry, so optimal dry setup with todays soft suspension relies on certain suspension travel for max grip and proper tire management, slower times mean less weight transfer in corners meaning less suspension travel, in order to fix that you will want overall softer suspension for wet, and on top of that, different aero elements on the car may work with different efficiency at those lower overall speeds, which will affect the balance of the car, so it just logical to assume that there will be differences in aero as well between wet/dry conditions
race vs. quali setup has different requirements for the car, quali is all about getting tire temp up fast, and it has to last just a lap or two with little extra load on board (fuel), race is quite different, you might as well sacrifice some aero to have to use less fuel to last the whole race distance (wasn't an issue in quali), which in turn will have an effect on tire degradation
having such a simplistic view on the cars setup is robbing yourself of the information you can notice watching the race
