Counter rotating driveshafts
Well, would you?
Yes, the tire and chassis do not care about the direction of the input shaft.
75%
No, the forces would neutralize, keeping the car level as it moves forward.
No votes
No, the nose of the car would be forced down with the same intensity as a wheelie; an antiwheelie.
25%
Total votes: 4
roon
roon
412
If you installed planetary gearsets on the rear axle stubs of a dragster, such that the wheels would turn in the opposite direction of the driveshafts, and then pulled that dragster up to a starting line, and put the transmission into Reverse, would you still be able to pull a wheelie when the lets go green?
Greg Locock
Greg Locock
236
Re: Counter rotating driveshafts
It's called a free body diagram.
