What could cause this unusual tyre wear?
DiogoBrand
73
My father recently gave me the car that used to belong to him (well technically it still does), and the unusual tyre wear caught my eye.
This tyre has around 20k kilometers on it, it's a Pirelli P Z
ero Nero, dimensions are 225/50R17. It's currently at the front, but it has done some distance at the back as well, which explains the high wear on the inside since the back has a lot of camber. What I don't understand is, why is it that in the second and fourth grooves the TWI is already touching the ground, while the first and third are fine?
The tyre spent most of its life underinflated, since my parents aren't really careful with tyre pressures and it has done pretty much 50/50 distance in highway and urban traffic.
The car is a 2012 Chevrolet Cruze, and yes, these tyres will be replaced as soon as possible.
Big Tea
99
Re: What could cause this unusual tyre wear?
Assuming the geometry is right (my first thought)
Would it at some point have been on a corner with bad shock absorbers? Once the balance has been destroyed it can continue to 'bounce'.
I assume you have had it balanced, but it id then spun from the hub, not 'rolled' from the outside.
Another (way out) possibility, was it parked for a long while with one part of the tyre in the sun?
Another (way out) possibility, although you never see it these days, has it been repaired with a 'strip' inside?
Maritimer
Maritimer
19
Probably toed out, shoulder is scrubbing every time the car moves
DiogoBrand
73
It wasn't repaired and the shock absorbers are good.
I'm assuming the wavy wear was caused by the fact that it ran at the rear, where the negative camber caused the wear on the inside, and the wear in the middle was caused at the front. For some reason this car seems to wear the tyres in the middle even though they spent most of the time under the manufacturer recommended pressures.
Big Tea
99
DiogoBrand wrote:
02 Dec 2018, 20:47
That is the obvious conclusion I think. I do not know what suspension set up is on that car, but weight in the back could exaggerate it if the body rides lower.
Phil
66
I would have guessed that over the course of 20k, the tire has been subject to various different loads and pressures, causing uneven wear.
Too much pressure = car wears off in the middle of the tire.
Too little pressure = car wears off on the side.
Camber will also have a huge impact on how the tire wears out. The tire construction also plays a role there too.
#Team44 supporter
Big Tea
99
@DB, can you just clarify this is just the one tyre? not the same both sides?
Digging deep in my mental data base, the only other thing that comes to mind is a badly worn/adjusted wheel baring, but you would notice that? (yes?)
strad
117
Sir Stirling Moss
DiogoBrand
73
Big Tea wrote:
02 Dec 2018, 23:56
I'll actually check if both sides look the same tomorrow.
And as for the ones saying the wear in the middle is caused by overinflation: The manufacturer recommends 32psi, and it has spent most of its life way below that since my parents aren't very careful with tyre pressures. So either the manufacturer is recommending a pressure that's too high, or there's something else causing this wear.
Publiclyzai
Publiclyzai
Phil
66
DiogoBrand wrote:
03 Dec 2018, 02:57
Let me try again:
At one point or another, the tire was most likely overinflated, causing excessive wear in the center. Then the tire was underinflated and in conjunction to the camber, caused excessive wear on the tire inside. Thus the outside of the tire is least worn.
You said yourself, the tire has run at least 20k and also been used at the front and rear. There’s reasonable assumption the tire has gone from at the very least correct pressure (most likely overinflated) to underinflated state, but i’d also guess there’s a chance at one point or another, pressures were increased in a routine check.
Also, an underinflated tire will be subject to all kinds of forces and deformation. Basically, the bulk of the load sits on the tire wall, but even so, there is a certain construction of the tire to take into account as well. What you are seeing as weird, isnt really that weird once you account for all that.
#Team44 supporter
Had zero nero's too before. great tires, grippy, but sensitive. they need perfect adjustment by the garage to have equalized wear. mine too had odd wear patterns. given, they had tiny walls due to the high rim size.
i noticed they responded very sensitive to the shape of the road. if the asphalt had 'wear' in it; it had the tendency to follow that line, far more than any other tires i've ran.
my favourite remain toyo proxes r888 and nitto nt05
i had dunlop direzza's too, i did enjoy those better in rainy conditions too.
so in the end they might take the top spot, but the toyo's were sensational in contact.
Jolle
Jolle
133
Not a very strange wear pattern for a fwd car with wide tires. Due to the camber the load is mostly on the inside.
