I wonder what people think would be best for F1, as far as technical regulations and other rules go.
In my opinion there are two points to car racing, especially F1:
- Development, exploration, and innovation of new or underdeveloped technology.
- Providing entertainment. Especially on-track action, which is entertainment to everyone unlike calculating numbers.
So mine would be something like this:
- Since no-downforce probably wouldn't fly these days due to pervasive superficial reasons, I'd have a fully body based downforce, No wings, winglets, potrusions, and definitely none of the vortex generating horror. Similar to the more extreme ground effect cars, but..
- the sidewalls mandatorily higher than the middle to prevent sealing to the ground which would bring dangers.
- Abandon the morbidly counterintuitive heritage of open wheels. Wheels would be mandatorily covered by the chassis. Much better, for both safety and aerodynamics.
- Downforce levels would only be adjustable by changing leading and trailing edge elements.
- The chassis would have have mechanical strength regulations to avoid rubble breaking during contact(it would crumple into dust like nose cones instead) of a reasonable speed difference. For all four sides of course.
- Instead of a halo, a frame reinforced windscreen that extends to both sides, even behind the drivers eyes. To provide safety (from small object as well, and from the sides too) an to also provide a good (230Β° or more) field of view. Currently in F1 the drivers' peripheral vision is completely blocked. No wonder there are so many weird collisions.
- The drive would be full electric of course. (I see no reason to drag-on ICE technology, which is past it's time).
It'd be 4WD with torque vectoring and regen breaking only. And direct drive to avoid whining gears (screw noise!), which is also and underdeveloped concept. Set a hard limit on both power output and regen (can be tuned to get better racing). Otherwise the motor regulations would be extremely open, only banning very expensive/troublesome materials and concepts such as cryogenics. - Power storage would be any combination batteries and fuel-cells running on bio-producible alkanes (eg: butane).
At least as long as batteries are good enough that fuel-cells can be neglected. (Or at least if races can be done with 1-3 batter swaps) - Recuperative electromechanical active suspensions
- Non-pneumatic tires, both for safety reasons and because they're a pretty undeveloped concept.
- Measures to avoid taller drivers being handicapped. Increased weight perhaps. Maybe shorter cars/wheelbase so midgets won't have as much of an advantage with ballast weights. (apart from current F1 stuff)
- No safety car. Slow zones instead, with multiple speed limits depending on severity of accidents/problems. They should be as short as reasonably possible, and would normally be only lifted when cars head through them an equal times.
- Tires that can last a whole race even with some abuse, otherwise tire changes with a minimum time. (I'm thinking 10 first and 15 thereafter) Fight it out on track. One compound for the race.
- Standing starts only, rain no excuse for not racing, the cars should be able to handle large amounts of water, including a reasonable thickness of pooling/flowing water.
- Not part of the formula, but races on better racetracks even if they don't live up to the ridiculous demands of the FIA security theater. (Would probably require splitting with the FIA, which is bonus in itself.)
- Emphasize car safety instead of butchered, horrible racetracks. And definitely no-tarmac runoffs. Instead use other means to slow cars, like a sort of artificial grass field, with long strong fibers. Minimal Kerbs, to suggest the edge of the track.
