Any comments about the shiny tyres?
Zynerji
110
Does this effect anything, or just a different surface treatment due to the new chrome moulds?
I would assume tyre blanket interaction would be slightly different on a new set, but probably negligible.
Any other thoughts on the subject?
Re: Any comments about the shiny tyres?
Just the surface finish from the moulds being plated.
39
Something I read from Pirelli said they used the chrome moulds because the tyre surface doesn't stick as much (which is why the surface appears shiny). I think the sticking to the moulds was actually tearing some of the softest compounds.
I actually like it because now you can instantly tell if it is a new or used set of tyres being bolted on.
coaster
16
Its probably mold release silicon based sprayed in before compression of rubber.
Chrome moulds.
Tzk
Tzk
34
Zynerji wrote:I would assume tyre blanket interaction would be slightly different on a new set, but probably negligible.
They usually heat the tires overnight anyways... so i assume this wont matter.
