an interesting insight from what is a theory, conspiracy
Not 100% sure, but I think this was original content from one of our members.
i am still looking for ways to improve...never was a good narrator to start with, never done it ever before. that was the second take..you should have seen the first one, probably you would be missing a few teeth by now if the path of evolution was different..i like your criticism so i can improve in quality, i hope..
Thought you did a fantastic job. Takes a lot of time to make these videos.pierrre wrote: ↑17 Apr 2019, 21:52i am still looking for ways to improve...never was a good narrator to start with, never done it ever before. that was the second take..you should have seen the first one, probably you would be missing a few teeth by now if the path of evolution was different..i like your criticism so i can improve in quality, i hope..
when i did that, there was no script...i guess thats one area that should be improved. the terms i used to explain too never consistent, always changing...and the animation too was class, i know. our neighbours dog as well just would not shut up regardless of how much i love the animal...that also played a factor in destroying whatever 'flow' i was trying to achieve
Didn't mean to cause any offense, but yes having a script would of been great or at least talking points and workings out how to transition into the different subjects you wanted to cover.pierrre wrote: ↑17 Apr 2019, 21:52i am still looking for ways to improve...never was a good narrator to start with, never done it ever before. that was the second take..you should have seen the first one, probably you would be missing a few teeth by now if the path of evolution was different..i like your criticism so i can improve in quality, i hope..
This image is actually quite an interesting one as it showcases something known as "vortex bursting". Vortex burst is a phenomenon of swirling flows whereby there is a sudden and quite drastic change in the structure of that same swirling flow.trinidefender wrote: ↑18 Apr 2019, 04:06The way that the cape works on the Merc is actually vey straight forward and one of the least complicated pieces of aerodynamics on the car (least complicated conceptually but very complicated to design)
They generate vortices. While facing the car from the front, clockwise on the left and counter clockwise on the right that feed to the barge boards of the car. Take a look at this picture and link if you want more information.
very kind words of support, thank you very muchzibby43 wrote: ↑17 Apr 2019, 23:06Thought you did a fantastic job. Takes a lot of time to make these videos.pierrre wrote: ↑17 Apr 2019, 21:52i am still looking for ways to improve...never was a good narrator to start with, never done it ever before. that was the second take..you should have seen the first one, probably you would be missing a few teeth by now if the path of evolution was different..i like your criticism so i can improve in quality, i hope..
Thank you for taking the time to create it.
none taken...while i was editing it...it was very obvious that some terms were all over the placeMaplesoup wrote: ↑18 Apr 2019, 08:13Didn't mean to cause any offense, but yes having a script would of been great or at least talking points and workings out how to transition into the different subjects you wanted to cover.pierrre wrote: ↑17 Apr 2019, 21:52i am still looking for ways to improve...never was a good narrator to start with, never done it ever before. that was the second take..you should have seen the first one, probably you would be missing a few teeth by now if the path of evolution was different..i like your criticism so i can improve in quality, i hope..
As i said overall I thought the content was great as well as the subject area and your take on it. It'll just take lots of practice to get a nice flow to things
i just finished a video on the front nose capetrinidefender wrote: ↑18 Apr 2019, 04:06The way that the cape works on the Merc is actually vey straight forward and one of the least complicated pieces of aerodynamics on the car (least complicated conceptually but very complicated to design)
http://www.aerospaceweb.org/aircraft/fi ... f18_46.jpg
https://static.rcgroups.net/forums/atta ... vortex.jpg
http://www.aerospaceweb.org/question/planes/q0176.shtml
The key here is that the vortices coming off of the cape rotate the same direction as the vortices coming off of the inboard edge of the front wing, the so called Y250 vortex. Vortices rotating in the same direction usually merge causing them to strengthen. Whether the two vortices are close enough to merge on the Merc doesn't seem to be conclusive.
