This is all split from the Honda PU topic, where it did not belong...
I am sorry if this will sounds unprofessional (I am not engineer), but regarding the new fuel for Honda, and what is the possible advantage of Ferrari: I read that the fuel flow sensor is using ultrasound along and against the fuel flow, and in this way measuring the Doppler effect in both directions, they can get the fuel flow rate. Well, this of course depends of the chemical properties of the fuel itself. So, is it possible Ferrari to have a fuel with different speed of sound in a way that it counts the legal limit of 100 kg/h but at the same time, the actual flow is greater than the limit? In this way, it is possible to have energy boost in one lap or at the beginning of the race but cannot use it constantly trough the race because you will run out of fuel.
