TJ brass bedplate expansion
coaster
16
The TJ V10 had an experimental brass bedplate clamped to an aluminium upper cylinder block.
The 2 different materials have expansion rates that dont match up ideal.
Does anybody have experience with such a difficult design problem, insights?
622
Re: TJ brass bedplate expansion
brass ?
not bronze then ?
bronze is a proper engineering material - brass isn't
the right bronze will have almost the same expansion coeff as brass but a higher elastic modulus and strength
manganese bronze seems best - it has higher expansion coeff than any brass
others might not be called bronze eg copper beryllium formerly known as beryllium bronze
(bear in mind dimensional changes on heat treatment - similarly with high expansion steels eg maraging steel)
Maritimer
Maritimer
19
Could be naval brass, which is bronze
622
well ..... Google tells me that ....
Naval brass and Admiralty brass are tin brasses ie tin is added to prevent dezincification
bronze doesn't have zinc so presumably doesn't dezincify itself
Maritimer
Maritimer
19
Could very well be, we always refer to it as bronze at my old job and in school but I dont know what its strength is like compared to true bronzes.
63l8qrrfy6
63l8qrrfy6
368
coaster wrote:
06 Feb 2020, 14:46
Not much of a problem.
Look at all the engines with aluminium heads on cast iron block running around with no trouble.
The bottom end is cooler and has less of a thermal gradient than the block/head joint.
In fact there are many examples of mating components in engines that have very different coefficients of thermal expansion: head/valve seats , head/valve guides, head/exhaust manifolds, any aluminium component bolted with a steel bolt, carbon fibre brackets bolted to aluminium (probably the most extreme combination).
As long as the components are designed to cope with the induced thermal stresses it shouldn't be a problem.
humble sabot
27
It's also a question of geometry. Higher aspect ratio objects have more apparent dimensional change. Hence the whole "coefficient" thing.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
