Air allways naturally goes from high to low pressure region,but here we has adverse pressure gradient,because low pressure is under floor but high pressure is at diffuser..
2)What is pressure distribution at F1 floor/diffuser?
viewtopic.php?f=6&t=15007IQ 240 wrote: ↑19 Jul 2020, 14:041)Diffuser reduce speed and increase pressure,so how diffuser accelerate air in front of it if we have adverse pressure gradient situation? Wouldnt be better that we put lower pressure(instead high) on end which will "pull"/accelarate air in front of it?
https://i.stack.imgur.com/bbUnF.jpg
Wouldn be better to put wing low pressure side on the end of floor,so low pressure from wing will "suck/accelarate air under floor,so in this case we dont have adverse pressure gradient-situation?Dr. Acula wrote: ↑19 Jul 2020, 22:37You have to differentiate what high and low pressure means in this case. The pressure in the diffusor ist still lower than atmospheric in this case.
The working of the floor-diffusor combination can be explained by bernoulli's principle. If you idealize the system, you can look at it as a constant massairflow under the entire underbody, which naturally means the flow must be faster where the cross-section is smaller otherwise the flow wouldn't be constant and faster flow means lower static pressure, at least as long as you stay subsonic.
