How carrying a full fuel tank vs fueling just enough plays out.
I believe in the long run it is faster to do the race with the tank full, than it is to fuel just enough to make the finish.
The reason being, if you can lean on the engine more, you can lean on the tires less and have the same lap time. Near the end, your tires will have more life because you've been leaning on the engine more than the chassis, and you'll be just as light as the underfueled car at the end of the stint, with the added benefit of having fresher tires.
hurril
hurril
Re: How carrying a full fuel tank vs fueling just enough plays out.
godlameroso wrote:
14 Nov 2020, 22:11
When the car is heavier and when you lean more on the engine is exactly when the tyres have to fess up the most.
hurril wrote:
14 Nov 2020, 23:08
godlameroso wrote:
14 Nov 2020, 22:11
I thought it was when you had to push hard in the corners. What is the difference between being marginal on fuel, or having a full tank? 5-6kg? Also which strategy is more flexible? With lighter cars I'd agree more with you, but the cars are much heavier than they were in the re-fueling days, which means the fuel makes up a smaller percentage of the weight of the car.
10lbs on a cat is much different than 10lbs on a tiger. Packing 10lbs on a house cat makes it a mega chonk, a tiger's paw weighs 10lbs.
Back in the refueling days, the cars were 560kg, before the hybrid era the cars were 630kg and could carry 150kg of fuel. Worst case scenario car weight was 780kg, these cars weigh 740kg with no fuel, and 855kg with a full tank.
10kg of fuel increases the weight of a 540kg car by 1.8% a 630kg car by 1.4%, but only 1.3% in a 740kg car.
100kg of fuel in a 540kg car is an 18% increase in weight vs a 13% increase in weight in a 740kg car.
hurril
hurril
godlameroso wrote:
14 Nov 2020, 23:10
hurril wrote:
14 Nov 2020, 23:08
godlameroso wrote:
14 Nov 2020, 22:11
The cars are heavier _and_ they carry around fuel for the whole race. I don't know how much fuel the cars would carry during the re-fueling days however.
The problem with your thoughts on pushing-in-the-corners idea is that the heavier car will have to "push less" to be on an even tyre-load with a lighter car. So it'll have to go slower _and then some_ to be able to actually reduce the wear. All of which would have to be compensated for by accelerating that much harder out of the corners to first compensate the initial "push less", then the "and then some" and on top of that they need that extra push to actually gain a time advantage.
SiLo
138
godlameroso wrote:
14 Nov 2020, 22:11
If this was the case, the smartest minds in engineering and strategy have been doing it wrong all these years.
Felipe Baby!
SiLo wrote:
15 Nov 2020, 19:32
godlameroso wrote:
14 Nov 2020, 22:11
They stop being human all of a sudden and become omniscient once they become f1 engineers?
hurril
hurril
godlameroso wrote:
16 Nov 2020, 20:07
SiLo wrote:
15 Nov 2020, 19:32
godlameroso wrote:
14 Nov 2020, 22:11
Which of these two only categories would you say you belong to here?
