Reverse gear
GM7
Reverse gear
Looking at the 2022 technical regulation and especially the article 9.8 "Reverse gear" i was wondering one thing...
Could a F1 Team used the electrical engine in order to drive the 1st gear backward ? The car would technicaly be able to be driven in reverse and the team could save a lot of weight using a full electric reverse.
What is your opinion about it ?
642
Re: Reverse gear
GM7 wrote:
14 Dec 2020, 01:48
yes of course
this is 4-quadrant hardware that at present is only called by the control software to work over 2 quadrants
henry
324
Re: Reverse gear
Would the ICE and all of it's ancillaries be happy to run backwards?
Jolle
Jolle
133
Re: Reverse gear
GM7 wrote:
14 Dec 2020, 01:48
https://zupimages.net/up/20/51/3r56.png
If you want the the car to reverse using an excising electric motor in the car you would need to decouple it from the ICE, this would add weight and another part that can fail. Adding another electric motor would mean the same.
Reverse gears on gearboxes don’t add a lot of weight, are non-performance parts and probably didn’t change much since the nineties. They are cheap, if they don’t work or break its no biggy etc.
Re: Reverse gear
GM7 wrote:
14 Dec 2020, 01:48
The water pump and oil pumps! Oh God! won't they think about the pumps?!
The engine may be safe to reverse for a short time, but other things will only work in one direction.
You could put little local gear sets to allow this, but a reverse gear would still be lighter and less complicated.
642
Re: Reverse gear
Jolle wrote:
14 Dec 2020, 13:44
why ?
Jolle
Jolle
133
Re: Reverse gear
Tommy Cookers wrote:
14 Dec 2020, 16:10
Jolle wrote:
14 Dec 2020, 13:44
why ?
Because the MHU-K is geared to the crank. If the electric motor would go in reverse, so would the crank. Of course you could do this, but I don’t think you want to suck a few cranks of air through the exhaust into the combustion chamber.
Big Tea
99
Re: Reverse gear
Jolle wrote:
14 Dec 2020, 17:27
14 Dec 2020, 16:10
Jolle wrote:
14 Dec 2020, 13:44
why ?
with 'reverse gear engaged' would the engine be turning backwards?
Jolle
Jolle
133
Re: Reverse gear
Big Tea wrote:
14 Dec 2020, 17:31
Jolle wrote:
14 Dec 2020, 17:27
14 Dec 2020, 16:10
why ?
With a reverse gear anyway... what’s the point to have it electric? Reverse gear is there because it’s in the rules, only to be used in emergencies by the drivers (because it’s fragile).
I assumed the reason to thought in the question was, why not ditch the reverse gear and just use the K motor? The answer to that is: you need a reverse gear.
Big Tea
99
Re: Reverse gear
Jolle wrote:
14 Dec 2020, 17:34
Big Tea wrote:
14 Dec 2020, 17:31
Jolle wrote:
14 Dec 2020, 17:27
Quite right, but what I had in mind when I read reverse is going to be required was to have a means for the driver to get a broken car off the track. most of the exits seem to be behind the barier and the car can reverse into it cleaaring the track
Jolle
Jolle
133
Re: Reverse gear
Big Tea wrote:
14 Dec 2020, 17:37
Jolle wrote:
14 Dec 2020, 17:34
Big Tea wrote:
14 Dec 2020, 17:31
In theory a nice idea, but that would mean that they have to change the whole way they operate the car. All is controlled by hydraulic pressure (gearbox, throttle, clutch, etc etc) for which the ICE has to run.
And besides that, even now if they retire a running car, they tend not to reverse it behind the barrier. If somehow it became rule, the best option would be a separate system on the diff with a gear like a starter motor and a complete separate system in the cockpit.
