You are very welcome.
Why will the last corner be tricky? If the wind is blowing to the SSE, the wind will improve as you go through the apex.godlameroso wrote: ↑21 Mar 2021, 14:34The wind will be blowing towards the SSE which means the track will be quite fast and the final corner will be especially tricky.
The wind helps you through 4, 6&7, 9&10 and 13.
You're going from cross wind to head wind, and can cause understeer on corner exit, or a loss of grip if you're not careful. Making it tricky, it's tricky to rock a rhyme that's right on time, but it's not impossible.Just_a_fan wrote: ↑21 Mar 2021, 15:48Why will the last corner be tricky? If the wind is blowing to the SSE, the wind will improve as you go through the apex.godlameroso wrote: ↑21 Mar 2021, 14:34The wind will be blowing towards the SSE which means the track will be quite fast and the final corner will be especially tricky.
Don't forget that the start straight is north/south with the last turn at the southern end.
It's the usual mind games. Like in war tactics you need to appear weaker than your opponent. If you win from the underdog position you undermine his mood.
With the torrential rains and flooding in Australia right now it's actually a blessing for F1 that it's in Bahrain this weekend.
Probably never going back, makes everyone’s life easier, and the teams will learn to work around it. One of the many things that will change permanently after the pandemic.SirBastianVettel wrote: ↑21 Mar 2021, 09:53I was hoping that teams would be able to choose their own tire allocation again this season.
