Zynerji wrote: ↑16 Feb 2022, 18:13
Would a team need 5% more (with relatively equal power)? 10%? Or is it as low as 1%?
I would go 1%.
If you work out the lap-time difference as a percentage (for last year) 1% would put you out in Q2 at best. If you go back to 2014, you could be almost 3% off if you had a Mercedes PU. Engines have been far closer in the last two years.
