This is my understanding of boat trim:
So implementing this on a car, you should get this:
My theory is they're using an engine damper for engine angle, a freespinning flywheel inside the rear differential (hidden and reason why some car exceed minimum weight) and a gyroscope to keep the car level in all modes. And they're controlling the rpm (mostly likely lowering) when engine load is not proportionate to downforce, effectively right before propoising.
My theory is that the have implemented this in a way to control not only propoising, but hysteresis, tire wear, effect on tire load and anti-dive/anti-squat by controlling the pitch on braking, essentially an FRIC what one team has done.
Or maybe they haven't, maybe it's done with the aero. But how would you control pitch aerodynamically as the rear ring angles out and diffuser pressure region decreases?
Using iceskates to level the car?
Bleeding the diffuser to keep the car level?
Stalling the beam wing to stop its effectiveness on the diffuser?
t-tray plank movement in the z-axis of rotation?
Source showing propoising in action at minute 2:40:
I believe a cavitation plate could also work.
But that's effectively another t-tray.
