https://www.designfax.net/cms/dfx/opens ... icle&pn=03
Although a car is not a cylinder like they used here, the flow image does show the two flows.
Some parts of the article
""For nearly a century, turbulence has been described statistically as a random process," said Georgia Tech's Roman Grigoriev. "Our results provide the first experimental illustration that, on suitably short time scales, the dynamics of turbulence is deterministic -- and connects it to the underlying deterministic governing equations."
The researchers created a new "roadmap" of turbulence by looking at a weak turbulent flow that was confined between two independently rotating cylinders -- giving the team a unique way to compare experimental observations with numerically computed flows, due to the absence of "end effects" that are present in more familiar geometries, such as flow down a pipe.
"Turbulence can be thought of as a car following a sequence of roads," said Grigoriev. "Perhaps an even better analogy is a train, which not only follows a railway on a prescribed timetable but also has the same shape as the railway it is following."
Hopefully this leads to a greater understanding and less time in the wind tunnel.
