Probably the word 'understeer' was the culprit. And I didn't mean that the car would suddenly become understeery mid-corner, after entering with neutral balance. I mean 'introduce a bit of understeer by removing a bit of DF from front => shift the balance more towards rear' - didn't mean the car has understeer w.r.t a neutrally balanced car. No.Emag wrote: ↑20 Sep 2024, 14:24There is no scenario where any driver would want to induce understeer mid corner, except to counteract snap oversteer. Understeer is especially hurtful on a long radius corner that you take as an example here.venkyhere wrote: ↑20 Sep 2024, 07:23I believe the prime benefit of flexi front wings is not 'reduced drag'. Reduced drag in a straight line at high speed, is a secondary benefit that. The prime benefit, according to me is in high speed corners. The FW flexes, reduce the front downforce, shifts the center of pressure rearwards in the car "automatically" and introduces understeer. That's what the driver wants in a long radius high speed corner. In slower corners, no FW flex, high downforce in the nose => helps rotate the car faster. This 'dynamic balance change to suit different types of corners' is the real benefit of a flexi FW.
The benefit of flexing wings comes from the fact that you can run with a lot more load at the front, without a drag penalty which would otherwise nullify the advantages in (certain) corners with losses on the straights.
What you say is not quite true. Of course a driver doesn't like extreme understeer. But in fast corners, an understeering balance is definitely preferred, as is a slightly oversteering balance in slow corners. It is therefore quite correct that the main aim of the flexible wings is to "adjust" the aerodynamic balance accordingly. In slow corners you want more "front bite" and a little more downforce at the front, while in fast corners the aerodynamic balance should move slightly towards the rear. No driver wants a car that constantly threatens to break out at the rear at 300 km/h.Emag wrote: ↑20 Sep 2024, 14:24There is no scenario where any driver would want to induce understeer mid corner, except to counteract snap oversteer. Understeer is especially hurtful on a long radius corner that you take as an example here.venkyhere wrote: ↑20 Sep 2024, 07:23I believe the prime benefit of flexi front wings is not 'reduced drag'. Reduced drag in a straight line at high speed, is a secondary benefit that. The prime benefit, according to me is in high speed corners. The FW flexes, reduce the front downforce, shifts the center of pressure rearwards in the car "automatically" and introduces understeer. That's what the driver wants in a long radius high speed corner. In slower corners, no FW flex, high downforce in the nose => helps rotate the car faster. This 'dynamic balance change to suit different types of corners' is the real benefit of a flexi FW.
Maurice Olley would have agreed with thatFarnborough wrote: ↑27 Sep 2024, 18:00,,, I think it should be most specifically about this trait in high speed, high torque/throttle application, avoiding the intricacies of low corner speed dynamics for clarity of topic.
