Good riddance.
https://www.roadandtrack.com/news/a6263 ... lap-point/
I agree with this. If any car gets fastest lap they deserve it if they are leading or in the drain. The time required will be the same for all "entrants" so should be the reward.
I was replying to the suggestion to open it up to not just the top 10 but all 20 drivers.Greg Locock wrote: ↑18 Oct 2024, 23:18"Because for some teams even just scoring 1 point was all the difference (travel costs reimbursed by FIA f.e.). They could park the car up for 20 laps during the race, put on fresh reds and super low fuel, go for it and retire the car with a “technical issue”." they had to be a top 10 finisher as well, a non trivial requirement.
Why not? They are there for points the same as the leaders. A point for fastest lap for say Williams is not going to affect the overall result but if they are in a contest with the other bottom 4 it adds interest to what would otherwise be just an also ran parade. I liked it when cars went to Lemans just to get the highest speed on Mulsane
P10-20, no points to earn from the results points allocation. So you then have 10 cars that arent going to score a point. They all pit on last lap, or drop to the back in order to be last out, bolt on a set of softs, and you have 10 cars that are going to be doing a qualifying lap at the end. As that 1 point is more than they would get than what they do now.Big Tea wrote: ↑19 Oct 2024, 00:33Why not? They are there for points the same as the leaders. A point for fastest lap for say Williams is not going to affect the overall result but if they are in a contest with the other bottom 4 it adds interest to what would otherwise be just an also ran parade. I liked it when cars went to Lemans just to get the highest speed on Mulsane
Is that a bad thing? 10 cars just going through the motions is no use to us as watchers or the sponsors who fund them.chrisc90 wrote: ↑19 Oct 2024, 00:37P10-20, no points to earn from the results points allocation. So you then have 10 cars that arent going to score a point. They all pit on last lap, or drop to the back in order to be last out, bolt on a set of softs, and you have 10 cars that are going to be doing a qualifying lap at the end. As that 1 point is more than they would get than what they do now.Big Tea wrote: ↑19 Oct 2024, 00:33Why not? They are there for points the same as the leaders. A point for fastest lap for say Williams is not going to affect the overall result but if they are in a contest with the other bottom 4 it adds interest to what would otherwise be just an also ran parade. I liked it when cars went to Lemans just to get the highest speed on Mulsane
Currently, there is no benefit of sticking some softs on and going for a fast lap at the end, as you dont get a point for FL currently. Only benefit is a driver taking a point off someone ahead of them in the standings.
