Wind tunnel technology
lio007
320
Wind tunnels became a talking point in the last couple of years with McLaren, Aston Martin and Red Bull investing in new facilities.
It's hard for me to figure out what is cutting edge technology in the wind tunnel sector. In what kind of aspects is a new wind tunnel better than an old one?
E.g. rolling roads
Does it make sense to use a 3-belt or is Single-belt used across all teams?
Greg Locock
Greg Locock
238
Re: Wind tunnel technology
The standard deviation of a round robin test on various wind tunnels around the world was ~0.01 for Cd, out of 0.30, and worse (in percentage terms) for lift at each axle.
So yes there is plenty of room for improvement.
Rodak
Rodak
37
Not to mention the 60% model size limitation; that would seem to possibly create correlation issues.
peewon
These two articles are a good insight into how wind tunnels are setup and what requirements are placed on wind tunnel testing under current aero regulations.
https://www.motorsport.com/f1/news/the- ... /10672095/
https://www.motorsport.com/f1/news/how- ... /10671540/
650
peewon wrote:
21 Jan 2025, 04:31
in the real world wind tunnel correlation actually means wind tunnel correlation
ie they now have full-size in-flight-measured transition points giving correlation to wind tunnel measurement
a wind tunnel model is a model of a fluid mechanics process not eg a model car
(at this generous scale) if the model car is unrepresentative in any way that's not a wind tunnel problem
lio007
320
So the challenge is to interpret the errors best that come along with a 60% model and limited wind speed.
What kind of angles (yaw, pitch and roll) can be tested in nowadays F1 tunnels?
Maybe they can't even afford to test aggressive angles because of the limited amount of test tyres they can use.
Greg Locock
Greg Locock
238
They don't use real tires in the wind tunnel, they are just black round things. Well I suppose that is obvious since nobody could make a 60% scale model of a tire that performed at 60%.
lio007
320
Greg Locock wrote:
21 Jan 2025, 22:15
They are using special wind tunnel tyres provided by Pirelli.
lio007
320
Silly question: I think all teams use a closed loop tunnel. These tunnels usually have 90° corners and use turning vanes.
What if a wind tunnel is designed in a circle instead of a rectangle? Would it be beneficial?
Although I think manufacturing costs might be quite high.
TNTHead
Greg Locock wrote:
21 Jan 2025, 22:15
Newey recalls in his book 'how to build a car' that they once had an aerodynamic instability issue due to tire flexing in high speed corners which was overlooked in the wind tunnel with the dummy tires. When they changed the dimension of the dummy tire to simulate the behavior during high speed cornering they were managed to overcome the issue. That was 15 years ago, shouldnt they have improved on such states, or can they check thst woth CFD?
Hoffman900
Hoffman900
220
Page 152 https://www.f1-forecast.com/pdf/F1-File ... 2e_all.pdf
And this is basically 20yo information now.
There are scaling issues with the tires and reynolds numbers. You can mimic flex in a static state with pull down rigs in the WT and having rams push on the inside of the tire.
However, a spinning wheel / tire and a static one produces big differences on the entire aero field.
CFD has correlation issues, and to do this correctly you need to model a flexing tire WHILE it is spinning, and that is not simple. Watch a tire in slow motion, it doesn’t just set into one deformed position.
650
Hoffman900 wrote:
26 Jan 2025, 20:49
There are scaling issues with ... reynolds numbers.
I would say not ...
the Reynolds number similarity is rather high
if this is inadequate then much of the US aircraft industry should have closed down
FW17
171
In the new ground-effect era, where the cars run closer to the ground, the interaction between the car floor and track surface has become a key performance differentiator.
Last summer Ferrari shut down its F1 wind tunnel to install a new ‘rubberised’ rolling road which, while less durable than the conventional steel belt, more accurately reflects the texture of a track surface.
https://www.motorsport.com/f1/news/why- ... /10693462/
ispano6
162
If you haven't already check out this article on Honda's HALO.
https://www.designnews.com/automotive-e ... ind-tunnel
Motorsport
Racing has its own demands of a wind tunnel, and those differ enough from the requirements of production car testing that it is difficult for one tunnel to be good for both purposes. Along with the variable nozzle, HALO overcomes this with other technology. “We have designed the tunnel to make the switch from road cars to race cars fast and efficient,” Unger explained.
It is the racing focus on downforce that makes the wide-belt system necessary. “For most road cars the focus is on drag, whereas for an Indy car or an Acura DPI machine the focus is not only reducing drag but also maximizing downforce,” he said.
“For racing, the ratio of drag to lift is known as aerodynamic efficiency, one of the primary focuses of development here at the wind tunnel. The majority of the downforce in a race machine comes from the undertray, which, with our unique wide-belt system, is specifically suited exactly for this capability.”
Other Key Features
HALO has other technical details that contribute to both the tunnel’s capabilities and to its efficient operation. Consider the need for engineers to know the frontal area of vehicles being tested in the tunnel. HALO has a system of cameras and lasers to provide that information quickly. “We can measure the frontal area as well as the side area of the car,” reported Unger. “This all feeds into the calculation, which allows us to get the very precise information we need when we are testing in the tunnel.
Not all aerodynamic testing is done with the vehicle pointed straight into the wind, so HALO is equipped with a 180-degree turntable. “This allows us to test at various, and sometimes extreme, yaw angles,” he said. “As well, it allows us to load and unload the car as quickly and as efficiently as possible.” Honda’s engineers are always looking at keeping the operation efficient!
HALO has a giant robot arm that reaches down from the ceiling to take measurements from anywhere inside the tunnel’s test section. The 80-ton arm carries a probe on its tip to measure pressure, velocity, sound or other conditions. “The purpose of this tool is to allow the test engineer to look into detailed phenomena to understand exactly what is going on with the flow field,” stated Unger.
Anyone who remembers Boyle’s Law and its description of the relationship between temperature, pressure, and volume of a gas will recognize the necessity of HALO’s heat exchanger, which preserves a consistent temperature in the tunnel for testing. It is also important to test vehicles are different temperatures, to understand the effect that has on their performance.
“We have the capability of changing the temperature between 10 degrees C and 50 degrees C,” he said. “The reason we do this is that cars are made of various materials, steel, aluminum, carbon fiber, plastic, rubber, and so forth. These all expand and contract at different rates. All of these things impact aeroacoustics and aerodynamics. With this capability we have the ability to understand that much more closely than in the past.”
FW17
171
Wonder if F1 teams can build desktop tunnels to test 15% models and make it accurate
https://livtab.com/products/windsible-d ... ind-tunnel
