DaveKillens wrote:Imagine the long, fast corner at Indy. A car picks up speed, then just entering the turn sees a big problem right ahead. But the driver is at full throttle, and as soon as he lifts, there is abrupt oversteer, and he does a Ralf into the wall.
That's the scenario if they still had the exhaust coming out down in the diffuser.
gcdugas wrote: I think you have that exactly backwards. With less exhaust gases to fill the diffuser, down frce would increase in response to the lo pressure zone. But this is beside the point, the exhaust used to exit beside the diffuser, not actually in it.
A wing has high drag to (negative) lift ratio. A diffuser almost gets its down force for free. That was the beauty of ground effects cars. They want high down force at all times. The exhaust never filled the diffuser. It would hurt the lateral grip exiting corners. It was on the sides of the diffuser. Think about the plumbing issues getting the pipes back to the center line. The gearbox is also in the way.mini696 wrote:I think the exhaust exiting into the diffuser helps more in high speed situations (or high rev).
My understanding of diffusers is that you want the hole to be 'empty' of air (at low pressure), therefore with no throttle (braking) the pressure is lower, therefore the downforce created is higher. At high revs (acceleration) the exhaust 'fills' the diffuser, and therefore creates less drag.
Au contraire. Anything that fills the diffuser would only detract from the low pressure zone and coresponding downforce.DaveKillens wrote:Technically, there can be as much as seven jones in a diffuser. Centerline, and as much as three on each side. The exhaust on older designs would exit somewhere, but definitely in the diffuser. The exhaust produces hot gases, but also when it exits the pipes, high velocity. That high velocity would boost the rest of the air velocity in that diffuser area, adding downforce to the rear.
But no matter what, shifting revs or sudden movements of the throttle would unsettle the delicate balance in the car.
