DaveKillens wrote:
This year, with everyone on basically the same tires, comparisons will be easier, and the weak and inferior concepts will be proven lacking.
This is the main point indeed, the single tyre supplier will make situation different from recent years.
Till 2006 the “marriage” tyre-car was a two way road, the team was working to adapt the car to the tyre, but contemporarily the tyre supplier was working to adapt the tyre to the car, so they could meet somewhere in the middle.
In 2007 it will be a one way road, the tyre supplier will say “that’s the tyre, adapt the car to it”. From the teams it will be required more “flexibility” in term of car’s design, suspensions, weight distribution etc etc should be easily modifiable allowing a big range of settings so that they can optimise the car to the tyre.
zenvision wrote:
do you buy autosprint reca? I find it really informative especially about ferrari and normally get their predictions spot on.
Yes I do, but, to be honest, it’s mainly tradition, I buy it since very long so even if often I’ve the temptation to stop, I somehow “can’t” do it. In the last few years I found that the quality continuously dropped, and even if there are interesting articles every now and then, many times it disappoints me a bit.
I find the other weekly, Sportautomoto, to be definitively better, I buy it since the 3rd or 4th issue in 2001 and it constantly improved in the years.
Then since a few months, when Piola switched from Autosprint (where he had less and less space) to Sportautomoto, the difference is even more evident.
In term of predictions they are more or less equal, meaning that they are often right and sometimes wrong, as it’s normal.
The only “problem” with Sportautomoto is the lower quality of paper, it’s more similar to a newspaper than a magazine so isn’t the best if you want to collect them.
Do you watch the race with Italian coverage in Malta ?
G-Rock wrote:
PS The Mclaren wasn't fast in 06 because of reliability and aero reasons. In 05 that was less of an issue, nothing to do with it's lack of keel. That would be a shallow assumption.
Which was precisely my point, success or failure isn’t down just to a single element.
Nevertheless, we can’t deny that in F1 often team’s design choices follow the trend set by the car that apparently the previous year looked like the best one (even if it didn’t win the WDC/WCC), it happens every year, monkey see monkey do. And that’s undoubtedly the case with the single keel, twin keel, no keel, in the recent years. How many cars in 2006 followed that path seeing that in 2005 the Mp4/20 used it ?
Obviously that’s something that happens mainly in small teams not having possibility to analyse deeply many solutions in design phase, hence take shortcuts (if they, the top team, adopted it, it means that it was the best solution so let’s work on it) with the hope to find the “jolly”, typically top teams prefer to follow a coherent evolutionary path based on the mass of data they accumulated in the years.
