is it linear with grip, so if a car has a whole load of downforce does it or does that not wear the tire more?
Is it a static vs kinetic friction issue?
I think I understand your question.ketanpaul wrote:Even I wanted to ask a question on tyre wear, what makes just one specific tread disappear during a race?
I would venture to say there isn't much heat generated by tire scrub ("skidding"). Heat in tires is generated by elastic deformation (onset of slip angle or slip ratio). This is why if you look at instantaneous tire temps going through a corner they can jump 40F easily.DaveKillens wrote:Generally, if a tire skids or slips, wear and abrasion happens. Then usually, more heat is generated, that helps make matters worse. If the tire gets too hot, wear is accelerated as well as loss of grip. It's a vicious cycle.
Disagree. How do you figure there is less slipping? Regardless of how much downward force there is on the tire you're still driving it to the limit of adhesion in high-performance racing. As you push from the peak grip level of the tire to the ultimate grip level (grip falls off slightly from peak) the contact patch is no longer purely gripping at slip angle but starts to slide as well. I would say higher downforce = higher tire wear rates due to the fact you're putting that much more load on the tire and driving it to its absolute limit of adhesion.But usually, if you increase downforce, tire wear is less because of less slipping.
This is not correct! Elastic deformation is recoverable and energy is not dissipated. Heat is generated as a result of viscous, or plastic flow and is non-recoverable. If you look at the stress/strain properties of the rubbers used in tyres you will see that at particular frequencies there is a significant viscous component in the strain response and this leads to the loss of energy as heat.Heat in tires is generated by elastic deformation
Are you referring to viscous flow as a permanent reorganisation of the molecules?Mikey_s wrote:Jersey Tom,
When the tyre is manufactured the compound is a mixture of rubbers, fillers and other stuff which is "cured", or crosslinked, chemically. The reaction is initiated by heat and the manufacturers stop the reaction when the desired properties are reached. However, there are still reactive sites in the compound which can be re-activated by heat. Part of the knowledge the teams build up with their tyre supplier is how the tyres react to further heat cycles (either through track action, or by sticking them in an oven). Therefore the tyre does not have fixed properties and the compound can, and does change its properties during use.and would soon find yourself driving around on something different to what you mounted on your car
