Hi,
This is my first post here. I am a student from Concordia University in Montreal, Canada, and preparing a little project/report whose subject is aerodynamic analysis of front wings of f1 cars.
Although I have been reading lots of posts from this forum and the pages I found through links posted here, am still not sure what to check for on my analysis. I know that the most important issue is having higher down-forces, therefore I checked forces on upper surface and lower surface of the wing. Another method, I guess, may be checking the pressures on both surfaces. But, still not sure whether I am doing it right.
I am posting two images and a small portion of results. Any kind of critics/comments and help greatly appreciated.
http://www.tayse.com/wing
Posted images and results just for test purposes, so do not mind the primitive shapes. I am going to model a couple different wings from different teams, maybe modify them slightly then test them and compare the results.
Thanks in advance for your help,
Taylan.
