I heard that around 60mph the car only relies on mechanical setup, as the air doesn't flow fast enough to make downforce. Around 100mph and above, its more about aerodynamic grip.uzael wrote:I suppose I am a bit confused by the importance of each. Obviously the more aero grip/ downforce you have the faster the car can go in turns before passing the laterl grip rating of the tires. But does mechanical grip operate in the same fashion? Does it work better at one speed while aero is better at another? Or do they work together as a combined force, with mechanical grip simply translating the aerodyanmic grip effectively to the ground? Any help would be greatly appreicated.
