Circuit Rating
kalyangoparaju
kalyangoparaju
Circuit Rating
guys can someone give me the info regarding the rating of circuits according to downforce...or atleast the highest,lowest and mid range downforce circuits
bar555
bar555
Re: Circuit Rating
Downforce set up
Very High downforce
Monaco
Hungary - Hungaroring
High downforce
Australia – Melbourne
San Marino – Imola
China – Sanghai
Brazil - Interlagos
Medium downforce
Bahrain - Sakhir
Malaysia – Sepang
Europe – Nurburgring
Spain – Barcelona
G. Britain – Silverstone
France – Magny Cours
Germany – Hockenheim
Turkey – Istanbull
Japan - Fuji
Low Downforce
Canada – G. Villeneuve
U.S.A. – Indianapolis
Belgium - Spa
Very low downforce
Italy - Monza
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
SoundMan
SoundMan
Re: Circuit Rating
not to sure spa is low downforce track. medium i would say.
Metar
Re: Circuit Rating
SoundMan wrote:not to sure spa is low downforce track. medium i would say.
The long straights meant that most teams used low downforce setups, with only some leaning towards medium setups.
Also, Fuji was also a rather low-downforce setup - just not this year in the rain.
Belatti
Belatti
Re: Circuit Rating
:cry: :cry: :cry: remember when hockenheim was on the last category ... :cry: :cry: :cry:
vyselegend
Re: Circuit Rating
I also think Fuji would need similar downforce level as indianapolis, being a half straight / half twisty track too. But indy has no quick turn (appart for the banked one), and Fuji has turn 4, which is taken at approx. 260km/h. This one needs reasonable DF level I'd say.
I'd say Bahrein and Spa are on the very low side of the "medium downforce list", while Hockenheim and Magny-cours are on the top, in terms of DF demands.
Metar
Re: Circuit Rating
The banked turn is taken flat-out with far less downforce anyway, so it's inexistent when downforce is considered.
At the same time, the faster corner at Fuji, I suspect, while obviously a consideration, shouldn't be much of a problem either, considering it's still a 1.5km straight we're looking at...
meves
meves
Re: Circuit Rating
and Valencia will be the next very high down force circuit as it appears to have almost no straight! I guess singapore will be high/medium???
Metar
Re: Circuit Rating
meves wrote:and Valencia will be the next very high down force circuit as it appears to have almost no straight! I guess singapore will be high/medium???
Yes, the circuit's resemblance to Monaco is striking - and it's even set near a marina as well!
vyselegend
Re: Circuit Rating
Metar wrote: Yes, the circuit's resemblance to Monaco is striking - and it's even set near a marina as well!
I had the same reaction first, but, as discussed on the Valencia-the track thread, the track is much wider and straights seems longer too.
Roland Ehnström
Re: Circuit Rating
The Valencia track is a fair bit longer than Monaco I believe, and definately wider. So when comparing the track layouts you should scale up the Valencia track-map, like this:
As usual, I could of course be completely wrong. :)
