The FW26 features a distinctively short nose cone, with the the front wing main plane and associated assemblies mounted on extended 'tusks' The startling interpretation of the front profile has been conceived in tandem with a twin keel monocoque design, aiding air flow both under and over the front geometries of the car, and improving global aerodynamics right through to the rear wing of the FW26. The car's behaviour now relies very much on the efficiency of the front under the nose, more than ever!
The efficient implementation of a twin keel design aids air to flow under the car smoothly, and allows a less turbulent airflow into the sidepods
The design was abandoned since then .............
