Unrestricted F1 car was something I (and maybe every F1 fan) have in their imagination. Afterall we all love speed.
I think that and unrestricted car would be very very dangerous to race, so first of all we would have to clone several Gilles Villeneuves, cause nowadays chicken-drivers would refuse.
Ciro Pabón wrote:Well, you could use robotic drivers to avoid stagnation. That'll kill the sport, unless you root for a robot...
Human tolerance to g-force
Human tolerances depend on the magnitude of g-force, the length of time it is applied, the direction it acts, the location of application, and the posture of the body.
The human body is flexible and deformable, particularly the softer tissues. A hard slap on the face may impose hundreds of g-s locally but not produce any real damage: a constant 15 g-s for a minute, however, may be deadly. When vibration is experienced, relatively low peak g levels can be severely damaging if they are at the resonance frequency of organs and connective tissues.
To some degree, g-tolerance can be trainable; and there is also considerable variation in innate ability between individuals. As well, some illnesses reduce g-tolerance, particularly cardiovascular problems.
Vertical axis g-force
Aircraft in particular exert g-force on the axis aligned with the spine. This causes significant variation in blood pressure along the length of the subject's body, which limits the maximum g-forces that can be tolerated.
In aircraft in particular, g-forces are often towards the feet, which forces blood away from the head; this causes problems with the eyes and brain in particular. As g-forces increase Brownout/greyout can occur, where the vision loses hue. If g-force is increased further tunnel vision will appear, and then at still higher g, loss of vision, while consciousness is maintained, this is termed "blacking out". Beyond this point losing consciousness will occur, also sometimes known as g-loc (loc stands for loss of consciousness). While tolerance varies, a typical person can handle about 5 g (49m/s²) before g-loc'ing, but through the combination of special g-suits and efforts to strain muscles—both of which act to force blood back into the brain—modern pilots can typically handle 9 g (88 m/s²) sustained (for a period of time) or more (see High-G training).
Resistance to "negative" or upward gees, which drive blood to the head, is much less. This limit is typically in the -2 to -3 g (-20 m/s² to -30 m/s²) range. The vision goes red and is also referred to as a red out. This is probably because capillaries in the eyes swell or burst under the increased blood pressure.
Humans can survive about 20 to 35 g instantaneously (for a very short period of time). Any exposure to around 100 g or more, even if momentary, is likely to be lethal, although the record is 179 g.
Horizontal axis g-force
The human body is considerably more able to survive g-forces that are perpendicular to the spine. In general when the g-force pushes the body backwards (colloquially known as 'eyeballs in'[3]) a much higher tolerance is shown than when g-force is pushing the body forwards ('eyeballs out') since blood vessels in the retina appear more sensitive to that direction.
Early experiments showed that untrained humans were able to tolerate 17 g eyeballs-in (compared to 12 g eyeballs-out) for several minutes without loss of consciousness or apparent long-term harm.
Some examples:
* Pilots in the Red Bull Air Race commonly exceed 10 g for seconds during turns, occasionally surpassing 12 g.
* Formula One drivers usually experience 5 g while braking, 2 g while accelerating, and 4 to 6 g while cornering. Every Formula One car has an ADR (Accident Data Recovery) device installed, which records speed and g-force. According to the FIA Robert Kubica of BMW Sauber experienced 75 g during his 2007 Montreal GP crash.
So, avoiding robots, definitively drivers would need anti-G suitsfor driving Unrestricted Designed F1 Cars.
Ciro Pabón wrote:...Please, don't think I'm a Buddhist, but if you watch the symbol of the "eightfold path" you can conclude the inverse: Buddha was a fan of racing.
To be more precise, I think Buddha was fan of snow racing, if you look close that type of wheel seems to have nails
