i got a little idea in my mind and i dont know if could work.
basically we put electroactive polymer (EAP) into a tire. electroactive polymer is contracting if voltage is applied on them. they use them to build artificial muscles
(http://en.wikipedia.org/wiki/Electroactive_polymers)
and why we need EAP in tire? so this is a part that i dont really know if could work but idea is that we use EAP to control the tire contact surface. ideally we can go from slick when we need traction to some pattern when we have wet road.
general idea was to go from slick when we need a lot of traction (for example when car is starting to move) to some other pattern when when car is already moving and we want to maintain that speed so we should lower the traction. again im not sure if we need lower traction (friction coefficient) when car is driving 100km/h on a highway and i dont know whats the difference between friction coefficient in slick tires and some pattern tires.
would this work?
well if doesnt work with friction coefficient changes it still could work with changing tire contact surface depending on dry or wet condition
