I was thinking about the regulations change next year (2009) and had an idea! As we all know, the apex turn speed is something crucial in modern formula 1 (especially since we've got the V8's). So what do you need to pass corner at maximum speed?
1.Downforce in order to have a better traction.
2.A low center of gravity
My idea focuses on the center of gravity. Because all masses are bound to the force of inertia we need a car with a center of gravity as low as possible.
If a car's center of gravity is to high, it will cant. And even if the cars center of gravity is low enough (like modern f1 cars) you loose some traction. ← The car is out of balance.
Picture 1.1 shows what its all about (I know it's not 100% physically correct, but it's only purpose is to give you a rough idea what I mean)
To balance the car again, we need more pressure on the inner side (inner wheels). One simple thing to achieve this, would be to increase the angle of all wings on the inner side. (if you dive a left corner, all the wings on the left side of the car). We could just split the wings into an A-wing and a B-Wing (like in picture 1.2). In picture 1.2 you see a front wing of a car. My idea is that you could adjust the wings angle separate (increase angle A without touching B's angle). It's quiet like the mechanism behind the aileron of a plane, with the difference that we just increase the angle of one side, instead of increasing one side and decreasing the other one. The wing angles must be controlled electronically, depending on the speed of the car and the angle of the steering wheel.
Picture 1.2 shows a front wing with wings A and B marked. (I just illustrated the front wing, in reality we would also use some winglets and maybe some parts of the back wing???) btw. I'm sorry for the bad paintings but I just got a piece of paper and my laptop (just touchpad)
That would give the car some advantages: A higher apex speed and better use the tires. The mechanism could also be used to avoid standing wheels (usually the inner front wheel) in the breaking zone.
I know that something like this is impossible (within the current regulations and also within next years regulations). But do you think this could give cars a real advantage? (more than 1/100 sec. per lap)
I'm really sorry about my bad technical english. English is (obviously) not my mother tongue.
