European GP Valencia - Braking Analysis
bar555
bar555
2008 DATA
The circuit is not demanding for brakes but low grip levels and the barriers just a few meters away made the teams to use HD-Heavy duty brake calipers with carbon discs 25mm thick
Type of brakings: Medium
Number of brakings: 8
Time spent under braking per lap: 16%
Kurve 1
Initial speed: 290 Km/h
Final speed: 214 Km/h
Stopping distance: 113 m
Braking time: 1.61 sec
Maximum deceleration: 2.1 g
Maximum disc temperature: 604 °C
Maximum pedal load: 41 Kg
Kurve 2
Initial speed: 308 Km/h
Final speed: 58 Km/h
Stopping distance: 119 m
Braking time: 2.92 sec
Maximum deceleration: 4.5 g
Maximum disc temperature: 1000 °C
Maximum pedal load: 144 Kg
Kurve 3
Final speed: 256 Km/h
Stopping distance: 37 m
Braking time: 0.48 sec
Maximum deceleration: 2.4 g
Maximum disc temperature: 597 °C
Maximum pedal load: 57 Kg
Kurve 4
Initial speed: 279 Km/h
Final speed: 93 Km/h
Stopping distance: 125 m
Braking time: 2.7 sec
Maximum deceleration: 3.3 g
Maximum disc temperature: 738 °C
Maximum pedal load: 105 Kg
Kurve 5
Initial speed: 284 Km/h
Stopping distance: 36 m
Maximum deceleration: 1.9 g
Maximum disc temperature: 621 °C
Maximum pedal load: 45 Kg
Kurve 6
Initial speed: 258 Km/h
Final speed: 79 Km/h
Stopping distance: 97 m
Braking time: 2.41 sec
Maximum deceleration: 3.9 g
Maximum disc temperature: 921 °C
Maximum pedal load: 122 Kg
Kurve 7
Initial speed: 288 Km/h
Final speed: 88 Km/h
Stopping distance: 111 m
Braking time: 2.46 sec
Maximum disc temperature: 943 °C
Maximum pedal load: 134 Kg
Kurve 8
Initial speed: 296 Km/h
Final speed: 81 Km/h
Stopping distance: 100 m
Braking time: 2.1 sec
Maximum deceleration: 4.7 g
Maximum disc temperature: N/A
Maximum pedal load: 143 Kg
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
axle
axle
Re: European GP Valencia - Braking Analysis
Thanks for the info. Out of interest where does it come from as the TV footage showed point 8 was a 5.0g stop repeatedly when on board with Hamilton.
- Axle
MattF1
MattF1
It's on Brembo (brake manufacturers) website. http://www.brembo.com/ENG/Formula1/2008/ Thanks to bar555 for making it more convenient for us though.
bar555
bar555
2009 DATA
Situated in Valencia's recently-revamped marina area, the track is 5.473 kilometres in length and boasts top speeds of over 300 km/h - the cars will reach 300 km/h or more five times per lap, and calculated an average speed per lap of 225 km/h which will be the eighth fastest of all Grand Prix tracks.
Three times per lap the drivers also have to brake to about 80 km/h which will be as demanding for the brakes as the Montreal circuit. The longest full throttle section will be along the harbour where the drivers will drive at full throttle for 13 seconds. The front straight is 185 metres long and the shortest of all Formula One circuits this year
The layout of the innovative track is challenging too, with 25 turns (11 left and 14 right) to test the drivers to the maximum
Length Km : 5.419
Number of laps: 57
Type of brakings: Heavy
Pole 2008: – 1:38.708 - F Massa
Pole 2009: – 1:39:498 - Hamilton
corners : 25 (11 right and 14 left)
Tyre compounds: Soft and Super Soft
Tyre Usage: Medium
Brake Wear: High
Downforce Level: High 7/10
Average Speed: 200km/h (124mph)
Kurve 1
Initial speed 2009 Km/h : 293
Initial speed 2008 Km/h : 302
Difference : -9
Final speed 2009 Km/h : 101
Final speed 2008 Km/h : 102
Difference : -1
Stopping distance 2009 m : 103
Stopping distance 2008 m : 107
Difference : -4
Braking time 2009 sec : 2,1
Braking time 2008 sec : 2,08
Difference : 0,02
Maximum deceleration 2009 g : 4,95
Maximum deceleration 2008 g : 4,8
Difference : 0,15
Maximum pedal load 2009 Kg : 133
Maximum pedal load 2008 Kg : 157
Difference : -24
Braking power 2009 KW : 2.062
Kurve 2
Initial speed 2009 Km/h : 238
Initial speed 2008 Km/h : 234
Difference : 4
Final speed 2009 Km/h : 133
Final speed 2008 Km/h : 108
Difference : 25
Stopping distance 2009 m : 58
Stopping distance 2008 m : 108
Difference : -50
Braking time 2009 sec : 1,18
Braking time 2008 sec : 1,44
Difference : -0,26
Maximum deceleration 2009 g : 3,63
Maximum deceleration 2008 g : 3,3
Difference : 0,33
Maximum pedal load 2009 Kg : 96
Maximum pedal load 2008 Kg : 106
Difference : -10
Braking power 2009 KW : 1.198
Kurve 3
Initial speed 2009 Km/h : 287
Initial speed 2008 Km/h : 289
Difference : -2
Final speed 2009 Km/h : 88
Final speed 2008 Km/h : 94
Difference : -6
Stopping distance 2009 m : 105
Stopping distance 2008 m : 101
Difference : 4
Braking time 2009 sec : 2,28
Braking time 2008 sec : 2,14
Difference : 0,14
Maximum deceleration 2009 g : 4,8
Maximum deceleration 2008 g : 4,6
Difference : 0,2
Maximum pedal load 2009 Kg : 128
Maximum pedal load 2008 Kg : 146
Difference : -18
Braking power 2009 KW : 1.957
Kurve 4
Initial speed 2009 Km/h : 189
Initial speed 2008 Km/h : 196
Difference : -7
Final speed 2009 Km/h : 81
Final speed 2008 Km/h : 81
Difference : 0
Stopping distance 2009 m : 59
Stopping distance 2008 m : 57
Difference : 2
Braking time 2009 sec : 1,64
Braking time 2008 sec : 1,64
Difference : 0
Maximum deceleration 2009 g : 2,71
Maximum deceleration 2008 g : 2,6
Difference : 0,11
Maximum pedal load 2009 Kg : 70
Maximum pedal load 2008 Kg : 82
Difference : -12
Braking power 2009 KW : 691
Kurve 5
Initial speed 2009 Km/h : 308
Initial speed 2008 Km/h : 312
Difference : -4
Final speed 2009 Km/h : 87
Final speed 2008 Km/h : 83
Difference : 4
Stopping distance 2009 m : 115
Stopping distance 2008 m : 113
Difference : 2
Braking time 2009 sec : 2,41
Braking time 2008 sec : 2,38
Difference : 0,03
Maximum deceleration 2009 g : 5,37
Maximum deceleration 2008 g : 5
Difference : 0,37
Maximum pedal load 2009 Kg : 144
Maximum pedal load 2008 Kg : 163
Difference : -19
Braking power 2009 KW : 2.351
Kurve 6
Initial speed 2009 Km/h : 192
Initial speed 2008 Km/h : 187
Difference : 5
Final speed 2009 Km/h : 155
Final speed 2008 Km/h : 152
Difference : 3
Stopping distance 2009 m : 22
Stopping distance 2008 m : 40
Difference : -18
Braking time 2009 sec : 0,46
Braking time 2008 sec : 0,4
Difference : 0,06
Maximum deceleration 2009 g : 2,74
Maximum deceleration 2008 g : 2,4
Difference : 0,34
Maximum pedal load 2009 Kg : 69
Maximum pedal load 2008 Kg : 76
Difference : -7
Braking power 2009 KW : 710
Kurve 7
Initial speed 2009 Km/h : 301
Initial speed 2008 Km/h : 303
Difference : -2
Final speed 2009 Km/h : 78
Final speed 2008 Km/h : 91
Difference : -13
Stopping distance 2009 m : 117
Difference : 9
Braking time 2009 sec : 2,58
Braking time 2008 sec : 2,18
Difference : 0,4
Maximum deceleration 2009 g : 5,18
Difference : 0,38
Maximum pedal load 2009 Kg : 139
Maximum pedal load 2008 Kg : 151
Difference : -12
Braking power 2009 KW : 2.219
Kurve 8
Initial speed 2009 Km/h : 297
Initial speed 2008 Km/h : 296
Difference : 1
Final speed 2009 Km/h : 66
Difference : -15
Stopping distance 2009 m : 182
Stopping distance 2008 m : 100
Difference : 82
Braking time 2009 sec : 2,84
Difference : 0,74
Maximum deceleration 2009 g : 5,06
Maximum deceleration 2008 g : 4,7
Difference : 0,36
Maximum pedal load 2009 Kg : 135
Maximum pedal load 2008 Kg : 143
Difference : -8
Braking power 2009 KW : 2.135
data source : Brembo
data process : bar555
