I was wondering: what cads other than catia are really excelent?
and how much does catia cost?
Cand anyone just buy catia or do you have to be a huge corp?
What exactly do you have in mind as an use for it?thestigm5 wrote:I was wondering: what cads other than catia are really excelent?
Try http://www.rhino3d.com.thestigm5 wrote:planning ion using it just to basically mess arounf=d design cars, planes
BTW, nowadays Rhino demos will last for 25 saves, no time bombs. And the Rhino news group is the best support availiable in the CAD industry.The FOZ wrote:I've used AutoCAD, and SolidWorks extensively, and spent a bit of time on Rhino3D.
AutoCAD is a waste of time, IMO. Line and drawing based drafting just doesn't lend itself to good 3D designs, or make it easy to generate complex assemblies. And the 3D engine is pretty much as sophisticated as cave paintings.
Rhino...I never could get my head around. It just wasn't intuitive to me. So I let my demo expire, now I get emails from Rhino every month or so...lol
I do like Solidworks, because it seems to be relatively simple to get going with. It is a little bit un-intuitive in terms of the user interfaces, for example, when drawing a line, you draw the line, then have an opportunity to set the length automatically...but if you happen to move your mouse in the meantime, it's already moved on and you can't manually enter a length. Then, on the flipside, if you were, say, drawing a sheet metal flange, you'd specify the flange location, then you put in the length, rather than how lines work.
It's decent, but a bit buggy. 2009 seems to be an improvement in some respects.
