Single Seater Rear Tie Rod Query
P34 lurv
P34 lurv
Apologies for a basic question: can anyone confirm the function of a rear tie rod on a single seater, such as a F3.
Thanks
alexbarwell
alexbarwell
Re: Single Seater Rear Tie Rod Query
Might be misunderstanding the question slightly, but the upper and lower wishbones are mainly arranged to handle the vertical wheel travel and the complex arc described by the wheel, but the attachment of the hub/wheel carrier does not locate the hub in rotation about the z-axis (normal notation) then the wheel could flap around the same as a broken track rod end - bit undesirable. Other than locating the wheel in the desired direction, toe in/out can be applied to suit.
Or did you not mean it in such a fundamental way?
I am an engineer, not a conceptualist :)
DaveKillens
DaveKillens
34
I believe this is the type of suspension arraingement you are referring to. Although the chassis may not be for a formula car, the suspension components are.
There are two tie rods (the two long straight, white, rods) per corner, an upper one and lower. Each locates the suspension uprights relative to the chassis.
xpensive
xpensive
214
Those tie-rods in your elegant picture DaveK, should be there to handle tyre-loads in their own very direction, acceleration and breaking, correct?
As I can recall, very common on F1 cars in the 70's.
DaveKillens
DaveKillens
34
xpensive wrote:Those tie-rods in your elegant picture DaveK, should be there to handle tyre-loads in their own very direction, acceleration and breaking, correct?
Fundamentally, correct. These tie rods do fix the location of the uprights as far as the fore and aft directions.
OT, I wish I could draw like that, my stick men are unreconizable and ugly .. lol
P34 lurv
P34 lurv
Many thanks to all - greatly appreciated
DaveKillens
DaveKillens
34
P34 lurv, most of us are here to learn, myself included.
I do suggest you purchase a good book on racing cars, because the topic is so wondeful to learn about.
xpensive
xpensive
214
While at the same time, some of us are hopeless know-it-alls, myself included! *LoL*
Jersey Tom
Jersey Tom
It's there to control the steering of the tire, just like the front tie rods.
P34 lurv
P34 lurv
Do anyone have a recommendation?
ps why is an ackerman arm called an ackerman arm - and I know what it does!
Carlos
Carlos
The seminal Software and Books Thread started by Manchild.
viewtopic.php?t=1507
The Engineering Resource Thread
viewtopic.php?f=3&t=4813
DaveKillens
DaveKillens
34
P34 lurv wrote:ps why is an ackerman arm called an ackerman arm - and I know what it does!
Best I could find...
http://members.cox.net/bdfelice/Ackerman/ackerman.htm
Jersey Tom
Jersey Tom
Never heard of an Ackermann arm before.
P34 lurv
P34 lurv
Great link - good old Mr Ackerman - what a good use of doors and bits of string!
