Williams FW31
We@sel
Williams FW31
You can see new Williams FW31 on : http://williams.latphoto.co.uk/
A designer knows that he achieved perfection not when there is nothing left to add, but when there is nothing left to take away.
--Antoine de Saint-Exupery
Sawtooth-spike
Re: Williams FW31
Nice find.
Like the front nose. But the sidepod are still quite big.
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
We@sel
Re: Williams FW31
i70q7m7ghw
i70q7m7ghw
49
Re: Williams FW31
Sawtooth-spike wrote:Nice find.
As opposed to the rear nose? :lol:
Looks like they are trying to control the airflow with the bodywork, the bulge in the sidepods almost looks like it's trying to grow in to a chimney.
antrock
antrock
Re: Williams FW31
there are two extra intakes behind the airbox, one on each side. probably cooling for the flywheel?
Motley
Motley
Re: Williams FW31
Best livery they've had for a while....
Sawtooth-spike
Re: Williams FW31
is it just me does the underside of the nose look really fat? Like they are carrying alot of weight ahead of the front wheels.
Agerasia
Agerasia
Re: Williams FW31
I quite like the look of it to be honest. You can see a lot of work has gone into the front wing. The end plates are coming in quite a bit more than the other teams by the look of it, hennce the wavy wing.
I think as designs progress we will see more use of bulbous bodywork for channeling air as is present on the Williams.
They seem to have actually made quite a lot of effort.
Sawtooth-spike wrote:is it just me does the underside of the nose look really fat? Like they are carrying alot of weight ahead of the front wheels.
It's also very curved on the underside of the nose and then rises sharply to where it meets the suspension. This is done to reduce the drag on the underside of the nose section I suspect.
EDIT: I'd like to see a side profile as well.
"badically pressuring rosnerg " Ringo 05/10/2014
tomazy
tomazy
218
Re: Williams FW31
siskue2005
70
Re: Williams FW31
Motley wrote:Best livery they've had for a while....
this livery is just interim one
the actual one will be shown at Season opener or some say around Feb testing
xpensive
xpensive
214
Re: Williams FW31
I just hope that the actual livery will reveal more sponsorship than from shavers, watches and a bankrupt bank. Imagine, only four or five years ago, this was a serious WDC contesting team supported by giants like HP and BMW?
What happened WhiteBlue?
tomazy
tomazy
218
Re: Williams FW31
WhiteBlue
92
Re: Williams FW31
I'm actually missing Allianz which would mean desaster.
mike
mike
Re: Williams FW31
tomazy wrote:Image
what is that scoop on the top inlet???
could that be an AERO-KERS ??
xpensive
xpensive
214
Re: Williams FW31
Right on the money, there's a small turbine inside, charging a LiPo battery, in order to make better use of the wind-speed already paid for energy-wise.
