I was used to EA F12002 diff which was: 0-100%
low % means stable on corner exit, entry not so stable
high % means stable on entry, exit not so stable.
I had id set to 75%.
How do I replicate this with
Pump, power and coast?
So if you have the same % for power and coast then preload is irrelevant according to the above quote.Increase Power = Increase understeer under postive throttle
Increase Coast = Increase understeer under negative throttle
Increase Pump (4WD) Front wheels pull more than rear
Preload affects how quickly the transition between power and coast differential occurs. If you used a preload of '1' and slammed the throttle down you would get a very quick transition to whatever your power percentage was, the reverse would happen with taking the throttle off. With a higher preload the above effect would be a lot more gradual.
from SetupMatrix
