Jersey Tom wrote:Why would you like to know?
Why not?
Anyway, to answer the question - F1 teams don't particularly want downforce in a straight line - you don't need it there, all your doing is generating un-necessary "lift"-dependant drag.
All teams test with yaw rates to ***try*** and get more downforce in yaw than in straight lines.
Remember the big antlers on the McLaren over the past few years? That is what they were there for - get more out of the rear wing in the corners.
The really interesting question is - what is the downforce dropoff with sideslip.
[edit: realised I didn't have a rate in after yaw!]
Sideslip = constant yaw angle (deg)
Yaw rate = Dynamic yaw angle (deg/sec)
F1 cars can corner at stupidly high yaw rates, upwards of 50 deg/sec at places like Becketts (Silverstone) - but it is an extremely dynamic motion.
However, they don't like to be sideslipping much more than 5 degrees IIRC (but that could be more to do with tyre friction circles than aero - although I'd imagine the two are tailored to a degree).
