I know that many teams (outside of F1) use Nitrogen in tyres opposed to air. I know that this is because nitrogen (should) have no water molecules in it.
But how does nitrogen effect the spring rate of the tyre compared to air?
Regards,
Are you trying to tell me that the equation of state of Air (70% nitrogen) deviates considerably from nitrogen? And that they deviate considerably from the Ideal Gas law (pV=nRT)? In a change of about 100ºC and two or so atmospheres? I can believe there's some deviation from the ideal gas law, but I doubt the deviation from, I don't know, van der Waals equation of state, is noticeable.Flummo wrote:Water is not the issue, the thing is that nitrogen varies very little in volume when the temperature changes, and inside a tyre that translates to less change in pressure when the temp changes. Oxygen and other things we have in air causes a bigger pressure variation, and since tyre pressure is important for car handling that is bad on a race car. (Yes, there is water in air too, but that would be easier to remove that than to remove EVERYTHING from the nitrogen.)
I'm sorry this is BS. If you pop down and see Michelin or Dunlop at an LMS race they're using dried compressed air not nitrogen. Provided the air drier is of sufficient quality there is no difference between nitrogen or air.riff_raff wrote:The industrial nitrogen gas used to pressurize F1 tires is considered "dry". That is it has almost all moisture removed. Atmospheric air is mostly composed of nitrogen (78%), so chemically there is not much difference between compressed air and compressed nitrogen. The reason compressed air is not used in racing tires is that racing tires operate at temperatures above the boiling point of water. And since compressed air contains water vapor, the water vapor in the tire's air would turn to steam during a race. The water vapor's latent heat phase change would cause a rapid increase in the tire pressure, upsetting the handling of the car. Dry nitrogen has no water vapor present, so a tire inflated with it is much more stable over the tire's operating temperature range.
Regards,
Terry
The difference between nitrogen and air is small, but I believe that in Stepneygate it was discussed that Ferrari used CO2 and in that case there would be difference as CO2 is triatomic gas and has larger heat capacity that nitrogen.ubrben wrote:Once again (with feeling) the gas you use is irrelevant provided the moisture content is low.
Ben
Well, I don't know what you call "considerably", but, as usual, you all know my preferred style (long posts with lots of back of the envelope numbers, long live F1Technical!).Miguel wrote:Are you trying to tell me that the equation of state of Air (70% nitrogen) deviates considerably from nitrogen?
